メインコンテンツにスキップ
Chromebook x360 14-da0011dx Motherboard Replacement
必要な工具と部品
  1. Chromebook x360 14-da0011dx Motherboard Replacement, Lower Case: 手順 1、 1の画像 1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 2、 2の画像 1 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 3、 3の画像 1 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 3、 3の画像 2 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 3、 3の画像 3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Motherboard Replacement, Battery: 手順 4、 2の画像 1 Chromebook x360 14-da0011dx Motherboard Replacement, Battery: 手順 4、 2の画像 2
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 5、 2の画像 1 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 6、 1の画像 1
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Motherboard Replacement, Fan: 手順 7、 1の画像 1
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 8、 2の画像 1 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 8、 2の画像 2
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
  9. Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 手順 9、 3の画像 1 Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 手順 9、 3の画像 2 Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 手順 9、 3の画像 3
    • Lift the ZIF connector locking flaps, then remove the ribbon cables.
    • There are several small connections for the ribbon cables. Exercise extreme caution when disconnecting the cables.
    • One ribbon cable is on the underside of the motherboard and will be removed later.
  10. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 10、 1の画像 1
    • Remove the three 3.0 mm Phillips #1 screws holding the motherboard in place.
  11. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 11、 3の画像 1 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 11、 3の画像 2 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 11、 3の画像 3
    • Disconnect the cables attached to the Wi-Fi card and motherboard along the top edge.
    • The leftmost connector is a ribbon-style connector with a metal locking bar that must be unlatched.
  12. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 12、 3の画像 1 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 12、 3の画像 2 Chromebook x360 14-da0011dx Motherboard Replacement: 手順 12、 3の画像 3
    • Use a spudger to remove the tape and plastic shielding that secure the wires.
  13. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 13、 1の画像 1
    • Gently lift the motherboard until it is loose.
    • Disconnect the ribbon cable attached to the underside of the motherboard.
    • The locking flap on this ribbon cable must be flipped down to unlock.
  14. Chromebook x360 14-da0011dx Motherboard Replacement: 手順 14、 1の画像 1
    • Lift the motherboard from the device.
    • Removal of the heat pipes may be necessary for replacement if your new replacement motherboard doesn't have one installed.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jake Williamson
メンバー登録日: 02/14/23
559 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team 1-2, Virtue Spring 2023 Western Carolina University, Team 1-2, Virtue Spring 2023人のメンバー
WCU-VIRTUE-S23S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 26
今までの合計 244
