メインコンテンツにスキップ
Chromebook Pixel (2013) Battery Replacement
必要な工具と部品
  1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: 手順 1、 2の画像 1 Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: 手順 1、 2の画像 2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 手順 2、 3の画像 1 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 手順 2、 3の画像 2 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 手順 2、 3の画像 3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Chromebook Pixel (2013) Battery Replacement, Pop it open: 手順 3、 2の画像 1 Chromebook Pixel (2013) Battery Replacement, Pop it open: 手順 3、 2の画像 2
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): 手順 4、 2の画像 1 Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): 手順 4、 2の画像 2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
  5. Chromebook Pixel (2013) Battery Replacement, Remove the bottom cover: 手順 5、 1の画像 1
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  6. Chromebook Pixel (2013) Battery Replacement, Release the battery: 手順 6、 1の画像 1
    • Remove the screws holding the battery in place.
  7. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: 手順 7、 2の画像 1 Chromebook Pixel (2013) Battery Replacement, Unplug the battery: 手順 7、 2の画像 2
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  8. Chromebook Pixel (2013) Battery Replacement, Examine the new battery: 手順 8、 1の画像 1
    • Make sure that the wattage and voltage matches the values of the old battery
  9. Chromebook Pixel (2013) Battery Replacement, Install the new battery: 手順 9、 2の画像 1 Chromebook Pixel (2013) Battery Replacement, Install the new battery: 手順 9、 2の画像 2
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
終わりに
8 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Kevin Fessler
メンバー登録日: 04/16/16
1,770 ポイント
4のガイドは作成済み
2 件のコメント
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - 返信
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 28
今までの合計 7,065
