メインコンテンツにスキップ
HP Chromebook 14-x015wm Battery Replacement
必要な工具と部品
  1. HP Chromebook 14-x015wm Battery Replacement, Battery: 手順 1、 2の画像 1 HP Chromebook 14-x015wm Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn the Chromebook upside down so that the bottom is facing upwards.
    • Remove the small rubber circles from all four corners.
    • Remove the other three rubber pads from the bottom
    • Proceed to unscrew all the screws.
    • Keep the screws on a magnetic mat or in a secure location and keep track of which screws went where.
  2. HP Chromebook 14-x015wm Battery Replacement: 手順 2、 1の画像 1
    • Flip the laptop back over and open it so that the keyboard is revealed to you.
    • Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
    • Be careful of the ribbons underneath that connect the keyboard to the internal components.
  3. HP Chromebook 14-x015wm Battery Replacement: 手順 3、 2の画像 1 HP Chromebook 14-x015wm Battery Replacement: 手順 3、 2の画像 2
    • The long, flat, black component that takes up the majority of the space is the battery.
    • All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
    • Make sure to keep track of where the screws came from.
終わりに
作成者
6人の作成者と共同で作成されました。
Cameron Sinclaire
メンバー登録日: 10/27/17
201 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 35
今までの合計 1,381
