はじめに
This guide is intended for use on engines already removed from the vehicle. While this kind of work may be possible to complete with the engine still in the car, it will be much easier with the engine removed.
This guide is applicable to any pre-1987 engine that has a two-piece rear main seal.
The rear main seal is what seals the tail end of the crankshaft so that oil does not leak out and external debris cannot get in.
必要な工具と部品
Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
Remove the two 5/8 rear main cap bolts. Gently tap the side of cap with a rubber mallet if needed to break free.
Remove the rear main seal. The upper half of the seal can easily be removed by hand.
Loop the new bottom half of the seal through the slot indicated in picture.
Put the rear main cap back and torque to specs (65 ft.-lbs.) followed by the oil pump and torque to specs (60-70 ft.-lbs.)
To reassemble, follow these instructions in reverse order following manufacture recommended torque specs and sequences.
ある他の人がこのガイドを完成しました。
