はじめに
This guide is intended for use on engines already removed from the vehicle. While this kind of work may be possible to complete with the engine still in the car, it will be much easier with the engine removed.
The rear main bearing is located under the same cap as the rear main seal. This rear main bearing goes between the cap and the crank case in order to ensure a smooth, frictionless surface to the crankcase to rotate inside of.
必要な工具と部品
Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
Remove the two 5/8 rear main cap bolts. Gently tap the side of cap with a rubber mallet if needed to break free.
Remove the rear main seal. The upper half of the seal can easily be removed by hand.
Loop the new bottom half of the seal through the slot indicated in picture.
Put the rear main cap back and torque to specs (65 ft.-lbs.) followed by the oil pump and torque to specs (60-70 ft.-lbs.)
Remove the rear main bearing and replace.
Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
To reassemble your device, follow these instructions in reverse order. Torque rear main cap bolts to 65ft.-lbs. Torque oil pump bolt to 60-70ft.-lbs. Torque oil pan bolts to 12ft.-lbs.
