メインコンテンツにスキップ
Chevrolet Windshield Wiper Motor / Transmission Replacement
必要な工具と部品
    • Raise the hood.
    • Remove the negative terminal clamp from the battery. Should be 10 mm
    • Apply painters tape to the windshield under each wiper arm.
    • Use a mark to record the wiper arm position on the windshield
    • Remove Antenna, use the proper wrench to loosen the antenna from the base.
    • Pull the washer hoses off of the small studs near the wiper arm bases.
    • Open the plastic caps from the base of the washer arms, using the proper socket wrench, loosen and remove the hold down nut.
    • Remove the washer arms. They make a puller tool but you should be able to wiggle them back and forth and lift them off the stud.
    • Remove the plastic end covers by prying them off with a wide screw driver
    • Remove 2 clips on the front of the plastic grille.
    • Remove 2 bolts from each side of the plastic grille.
    • Pull up on the grille and disconnect the wiper fluid tube near the drivers fender. there should be a section that will pull apart to allow removal.
    • remove three bolts holding the wiper transmission to the body. There should be a rubber gasket on each one - do not remove them from the assembly.
    • Remove the power plug, squeeze the plug on the bottom and pull, it should release with little effort.
    • Now you have to wiggle the transmission back and forth in the fire wall area in order to get it out
    • Using a screwdriver, pry off the linkage from the motor arm.
    • Remove three TORX (30) screws which will separate the wiper motor from the wiper transmission.
    • NOTE - if you purchase the wiper transmission assembly from a Chevy dealership, it will probably come with a new motor already attached. This means you can skip this step.
    • Reverse the steps to install the wiper transmission assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
gjmi
メンバー登録日: 09/07/14
163 ポイント
1ガイドが承認済み
コメント 1 件
Linkage does not move
david carrizales - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 42
今までの合計 8,088
