メインコンテンツにスキップ
Chefmate TO-09 Timer Replacement
必要な工具と部品
  1. Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: 手順 1、 3の画像 1 Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: 手順 1、 3の画像 2 Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: 手順 1、 3の画像 3
    • Examine the condition of the appliance.
    • Remove the tray from inside the toaster oven before dissembling.
    • With the tray removed, this is a great opportunity to clean your toaster oven . Built up debris left over time could lead to functional issues in the future!
  2. Chefmate TO-09 Timer Replacement: 手順 2、 3の画像 1 Chefmate TO-09 Timer Replacement: 手順 2、 3の画像 2 Chefmate TO-09 Timer Replacement: 手順 2、 3の画像 3
    • Flip the toaster oven on its head so that its bottom side is facing upwards.
    • Use a Phillips #0 screwdriver to remove the four screws hidden underneath the legs of the appliance.
    • There are two legs covering the two screws in the front peg .
    • The other two screws are visible under the back legs.
  3. Chefmate TO-09 Timer Replacement: 手順 3、 3の画像 1 Chefmate TO-09 Timer Replacement: 手順 3、 3の画像 2 Chefmate TO-09 Timer Replacement: 手順 3、 3の画像 3
    • Return the toaster oven to its upright position and rotate it so its backside is facing you.
    • Use the Phillips #0 screwdriver to unscrew the four screws visible on the backside.
    • Keep track of loose screws for later re-assembly.
  4. Chefmate TO-09 Timer Replacement: 手順 4、 3の画像 1 Chefmate TO-09 Timer Replacement: 手順 4、 3の画像 2 Chefmate TO-09 Timer Replacement: 手順 4、 3の画像 3
    • With the appliance facing you, remove the top cover of the toaster oven to access the timer location.
  5. Chefmate TO-09 Timer Replacement: 手順 5、 3の画像 1 Chefmate TO-09 Timer Replacement: 手順 5、 3の画像 2 Chefmate TO-09 Timer Replacement: 手順 5、 3の画像 3
    • Use the flat screwdriver as a wedge and pop the timer knob out of place.
    • If you have difficulty removing the timer by hand, use a flat plier to pry off the timer knob.
  6. Chefmate TO-09 Timer Replacement: 手順 6、 3の画像 1 Chefmate TO-09 Timer Replacement: 手順 6、 3の画像 2 Chefmate TO-09 Timer Replacement: 手順 6、 3の画像 3
    • With the timer in hand, gently remove the two wires attached to the square object.
    • Unplug the timer wire gently, or else this may cause damage to the cables.
  7. Chefmate TO-09 Timer Replacement: 手順 7、 3の画像 1 Chefmate TO-09 Timer Replacement: 手順 7、 3の画像 2 Chefmate TO-09 Timer Replacement: 手順 7、 3の画像 3
    • Before replacing your timer with a new one, you may try to lubricate it first to see if it fixes the issue.
    • Apply WD-40 to the timer's slight peek edge.
    • Let the WD-40 sit and take effect for around 30 seconds or a minute after you spray it onto the timer.
    • The WD-40's oil will seep inside the timer, reaching the tiny gear of the timer.
    • WD-40 is flammable. Be sure to read the instruction label before using WD-40 Two-Way Spray Can.
    • Not cleaning/wiping off excess WD-40 oil on the timer will start a fire in the toaster oven.
    • You can test the timer using a flat head screwdriver to turn the timer to see if it ticks/works.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Andy Tran
メンバー登録日: 04/05/22
172 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 4-61, Briggs Spring 2022 CSU Los Angeles, Team 4-61, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22S4G61
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 16
今までの合計 350
