メインコンテンツにスキップ
Chef's Choice M115 Power Switch Replacement
必要な工具と部品
  1. Chef's Choice M115 Power Switch Replacement, Case: 手順 1、 2の画像 1 Chef's Choice M115 Power Switch Replacement, Case: 手順 1、 2の画像 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Power Switch Replacement: 手順 2、 1の画像 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Power Switch Replacement: 手順 3、 1の画像 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Power Switch Replacement: 手順 4、 1の画像 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Power Switch Replacement, Power Switch: 手順 5、 1の画像 1
    • Carefully lift the entire motor assembly out of the case.
  6. Chef's Choice M115 Power Switch Replacement: 手順 6、 2の画像 1 Chef's Choice M115 Power Switch Replacement: 手順 6、 2の画像 2
    • Using a screw driver, unclip the edges of the switch by pushing them inwards and nudging the switch out of the plastic casing. You will hear a click when the edges unhook from the casing.
  7. Chef's Choice M115 Power Switch Replacement: 手順 7、 2の画像 1 Chef's Choice M115 Power Switch Replacement: 手順 7、 2の画像 2
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • This may require a fair bit of force. Use caution to not damage the device, yourself, or your surroundings.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Hatontola malawo
メンバー登録日: 09/17/15
147 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S3G3
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 324
