メインコンテンツにスキップ
Chef's Choice M115 Power Cord Replacement
必要な工具と部品
  1. Chef's Choice M115 Power Cord Replacement, Case: 手順 1、 2の画像 1 Chef's Choice M115 Power Cord Replacement, Case: 手順 1、 2の画像 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Power Cord Replacement: 手順 2、 1の画像 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Power Cord Replacement: 手順 3、 1の画像 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Power Cord Replacement: 手順 4、 1の画像 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Power Cord Replacement, Power Cord: 手順 5、 2の画像 1 Chef's Choice M115 Power Cord Replacement, Power Cord: 手順 5、 2の画像 2
    • Carefully lift the entire motor assembly out of the case.
  6. Chef's Choice M115 Power Cord Replacement: 手順 6、 1の画像 1
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
  7. Chef's Choice M115 Power Cord Replacement: 手順 7、 1の画像 1
    • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
終わりに
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Zachary Grounds
メンバー登録日: 09/17/15
580 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S3G3
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 525
