メインコンテンツにスキップ
Char-Broil Grill Burner Replacement
必要な工具と部品
  1. Char-Broil Grill Burner Replacement, Propane Heating Element: 手順 1、 1の画像 1
    • This is an exterior shot of the camping stove.
    • Make sure that you're in a well lit area with towels under the stove to catch any dislodged residue.
  2. Char-Broil Grill Burner Replacement: 手順 2、 2の画像 1 Char-Broil Grill Burner Replacement: 手順 2、 2の画像 2
    • Remove the lid by pulling straight up on its attached handle.
    • Next remove the top grill grate.
    • Grab one side of the grate.
    • Pull up on that side till you can get your hand under the edge.
    • Using both hands fully remove the grate.
  3. Char-Broil Grill Burner Replacement: 手順 3、 1の画像 1
    • Remove the heat distribution plate.
    • Place a hand on either side of the heat distribution plate and pull up.
    • The plate should pull straight out of the grill.
  4. Char-Broil Grill Burner Replacement: 手順 4、 2の画像 1 Char-Broil Grill Burner Replacement: 手順 4、 2の画像 2
    • Turn the stove on its side so that the bottom is easily accessible.
    • There is a single Phillips Head screw to remove in the center of the stove's bottom.
    • Fully remove this screw to detach the heating element from the main stove body.
  5. Char-Broil Grill Burner Replacement: 手順 5、 1の画像 1
    • Turn the stove back onto its legs after removing the bottom screw holding it.
  6. Char-Broil Grill Burner Replacement: 手順 6、 3の画像 1 Char-Broil Grill Burner Replacement: 手順 6、 3の画像 2 Char-Broil Grill Burner Replacement: 手順 6、 3の画像 3
    • Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
    • Pull up on the heating element, it should be free floating.
    • After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Dan
メンバー登録日: 10/01/17
155 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team S5-G1, Galliah Fall 2017 Michigan Tech, Team S5-G1, Galliah Fall 2017人のメンバー
MTU-GALLIAH-F17S5G1
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 44
過去 30 日: 86
今までの合計 650
