はじめに
According to this guide can easily replace the home security door cylinder.
必要な工具と部品
It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
Remove the two screws.
Use pry bar carefully pry around, you can remove both sides of the door handle.
Remove the lock cylinder lock screw.
Push the lock cylinder to one side of the door, which side is easy to push.
Please re-install in the reverse order of this guide.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
irlandaさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
