メインコンテンツにスキップ
Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement
必要な工具と部品
  1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Position Device: 手順 1、 1の画像 1
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: 手順 2、 2の画像 1 Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: 手順 2、 2の画像 2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel: 手順 3、 1の画像 1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: 手順 4、 2の画像 1 Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: 手順 4、 2の画像 2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Motherboard: 手順 5、 1の画像 1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
  6. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate Dial: 手順 6、 1の画像 1
    • The dial is located in the central part of the device.
  7. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Dial: 手順 7、 1の画像 1
    • Carefully remove dial from device by lifting upward.
    • Clean existing dial or replace if necessary.
    • Take care not to lose the small ball bearings.
  8. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate and Remove Ball Bearings: 手順 8、 1の画像 1
    • Locate ball bearings. Carefully remove.
    • If both ball bearings are still present, try lubricating ball bearings with multi-use lubricant.
    • If one or both ball bearings are missing, simply replace.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Anna Kihm
メンバー登録日: 10/13/14
956 ポイント
5のガイドは作成済み
チーム
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S2G4
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 17
今までの合計 2,150
