はじめに
This is a guide on how to replace the anchor arm. These arms connect the control arms to the lenses to adjust the focal length.
必要な工具と部品
Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
Remove the top cover of the focus knob as shown. Simply twisting and pulling the cover will slide it off.
Locate the panels in front of the binoculars between the middle axle and the viewing lens and simply pry them off with your fingers
Identify the panel on the side you wish replace the anchor arm on, as marked on the photo.
Cut the panel open with a knife. Cut the adhesive substance around the panel with the knife and then using said knife, you should be able to lift it off.
