メインコンテンツにスキップ
Celestron HomeCast Lite 47020 Main Unit Battery Replacement
  1. Celestron HomeCast Lite 47020 Main Unit Battery Replacement, Main Unit Battery: 手順 1、 1の画像 1
    • Left: Remote sensor; Right: Main unit
    • In this guide, we will replace new batteries for the main unit.
    • Before beginning, gather the following tools and replacement parts: Replacement battery (compatible with Celestron HomeCast Lite 47020) Small Phillips-head screwdriver Plastic opening tool (optional but helpful) Clean cloth or workspace
  2. Celestron HomeCast Lite 47020 Main Unit Battery Replacement: 手順 3、 3の画像 1 Celestron HomeCast Lite 47020 Main Unit Battery Replacement: 手順 3、 3の画像 2 Celestron HomeCast Lite 47020 Main Unit Battery Replacement: 手順 3、 3の画像 3
    • Power off the Celestron HomeCast Lite 47020 and unplug it from any power source. This will help avoid electrical hazards and prevent accidental activation during the repair.
  3. Celestron HomeCast Lite 47020 Main Unit Battery Replacement: 手順 4、 1の画像 1
    • Locate the battery compartment on the back of the unit. If secured with screws, use the Phillips-head screwdriver to remove them. If secured with latches, gently use the plastic opening tool to release them.
    • If the compartment has latches, use the plastic opening tool to carefully release them. Avoid using excessive force to prevent damage to the compartment or cover.
    • Once the compartment is open, gently lift the old battery out. If it's secured with clips or adhesive, use the plastic opening tool to carefully release it without damaging surrounding components.
    • If the old battery is swollen, damaged, or leaking, wear gloves to handle it safely. Dispose of it according to local regulations.
    • Align the new battery with the compartment, ensuring the positive and negative terminals match. Press it gently into place without using excessive force.
    • Once the new battery is in place, replace the compartment cover. If screws were used, tighten them carefully with the Phillips-head screwdriver, ensuring not to overtighten.
    • Power on the device and ensure it functions correctly. If it doesn’t turn on or isn’t performing as expected, check the battery connections or consult the troubleshooting guide for assistance.
終わりに
作成者
6人の作成者と共同で作成されました。
xin zhao
メンバー登録日: 02/04/19
243 ポイント
2のガイドは作成済み
チーム
UC Davis, Team S18-G7, Lore Winter 2019 UC Davis, Team S18-G7, Lore Winter 2019人のメンバー
UCD-LORE-W19S18G7
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 28
今までの合計 134
