はじめに
This is a guide for replacing the control arm for the Celestron Nature DX 8x25 Binoculars. These arm connect the focus knob's axis to the anchor arms.
必要な工具と部品
Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
Locate the panels in front of the binoculars between the middle axle and the viewing lens and simply pry them off with your fingers
もう少しです!
終わりに
