はじめに
Replacing the display on this device is not very difficult. A couple sets of screws and wires are all that need removing, but don't rush or you might rip a cable.
必要な工具と部品
Lay the device on its back, and rotate so the base is facing away from you.
Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
終わりに
ある他の人がこのガイドを完成しました。
