メインコンテンツにスキップ
Caterpillar B15 LCD Replacement
必要な工具と部品
  1. Caterpillar B15 LCD Replacement, Caterpillar B15 Teardown: 手順 1、 1の画像 1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 LCD Replacement: 手順 2、 2の画像 1 Caterpillar B15 LCD Replacement: 手順 2、 2の画像 2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 LCD Replacement: 手順 3、 2の画像 1 Caterpillar B15 LCD Replacement: 手順 3、 2の画像 2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
  4. Caterpillar B15 LCD Replacement: 手順 4、 2の画像 1 Caterpillar B15 LCD Replacement: 手順 4、 2の画像 2
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
  5. Caterpillar B15 LCD Replacement: 手順 5、 1の画像 1
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
  6. Caterpillar B15 LCD Replacement: 手順 6、 1の画像 1
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
  7. Caterpillar B15 LCD Replacement: 手順 7、 1の画像 1
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
  8. Caterpillar B15 LCD Replacement: 手順 8、 1の画像 1
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
  9. Caterpillar B15 LCD Replacement: 手順 9、 1の画像 1
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
  10. Caterpillar B15 LCD Replacement: 手順 10、 1の画像 1
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
  11. Caterpillar B15 LCD Replacement: 手順 11、 1の画像 1
    • Congratulations. You have successfully disassembled the Caterpillar B15.
  12. Caterpillar B15 LCD Replacement, LCD: 手順 12、 1の画像 1
    • With the device completely disassembled, the LCD can easily be accessed. It is pictured here, in which it adheres to the front of the motherboard.
  13. Caterpillar B15 LCD Replacement: 手順 13、 1の画像 1
    • The LCD is held to the board by an adhesive, and will peel away with either a spudger or by hand. Disconnect any ribbon cables if applicable.
  14. Caterpillar B15 LCD Replacement: 手順 14、 1の画像 1
    • Installing the new LCD is the reverse of removing the old one. The 2mm 3M adhesive tape listed in the guide is recommended for fixing the new display to the board.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Geoffrey Mosdell
メンバー登録日: 10/06/14
1,119 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014人のメンバー
USFT-BROWN-F14S4G7
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 7,000
