メインコンテンツにスキップ
Cat5e RJ-45 Keystone Jack Replacement
必要な工具と部品
  1. Cat5e RJ-45 Keystone Jack Replacement, Cat5e RJ-45 Keystone Jack: 手順 1、 3の画像 1 Cat5e RJ-45 Keystone Jack Replacement, Cat5e RJ-45 Keystone Jack: 手順 1、 3の画像 2 Cat5e RJ-45 Keystone Jack Replacement, Cat5e RJ-45 Keystone Jack: 手順 1、 3の画像 3
    • Disconnect the Cat5e ethernet cable from any power source(s) before continuing.
    • Using utility scissors, cut in a circular motion around the jacket of the Cat5e ethernet cable until it is separated from the rest of the cable.
    • Slide the disconnected jacket off of the ethernet cable.
    • Cut around 1-2 inches from the edge of the Cat5e ethernet cable.
  2. Cat5e RJ-45 Keystone Jack Replacement: 手順 2、 3の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 2、 3の画像 2 Cat5e RJ-45 Keystone Jack Replacement: 手順 2、 3の画像 3
    • Using your utility scissors, cut a small inlet into the edge of the remaining ethernet jacket.
    • Avoid damaging internal wires during this process.
    • Using both sides of the cut inlet, peel the jacket around 3-4 inches further into the ethernet cable to expose more wiring.
    • Once the jacket is peeled, cut off the remainder of the peeled jacket with utility scissors.
  3. Cat5e RJ-45 Keystone Jack Replacement: 手順 3、 2の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 3、 2の画像 2
    • Turn the RJ-45 Keystone Jack on its side and examine the color coding provided.
    • Align each pair of wires with the designated color coding on the RJ-45 Keystone Jack.
    • There are four pairs of wires twisted together within a Cat5e ethernet cord. Two pairs of wires match the color scheme on one side of the RJ-45 Keystone Jack, and the other two pairs match the color scheme on the opposite side of the jack.
  4. Cat5e RJ-45 Keystone Jack Replacement: 手順 4、 2の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 4、 2の画像 2
    • Gently untwist each pair of wires to reveal eight individual wires.
    • Keep the separated wires together according to their colors. For example, keep the solid green wire close to the striped green wire, and so on.
  5. Cat5e RJ-45 Keystone Jack Replacement: 手順 5、 2の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 5、 2の画像 2
    • Using the appropriate wiring scheme, align each individual wire into the designated slot on the RJ-45 Keystone Jack.
    • There are two different wiring schemes available. These are labeled as scheme A and scheme B on the RJ-45 Keystone Jack. Make sure that the same wiring scheme is used on both ends of the Cat5e ethernet cord. If the other end's scheme is unknown, use wiring scheme B as it is the most common.
    • Striped cords align with the color blocks that have a white line crossing diagonally through the color coding.
  6. Cat5e RJ-45 Keystone Jack Replacement: 手順 6、 2の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 6、 2の画像 2
    • Align the other four wires into the designated slots on the other side of the Cat5e RJ-45 Keystone Jack.
    • Make sure that all eight wires are aligned according to the same wiring scheme on both sides of the RJ-45 Keystone Jack.
  7. Cat5e RJ-45 Keystone Jack Replacement: 手順 7、 3の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 7、 3の画像 2 Cat5e RJ-45 Keystone Jack Replacement: 手順 7、 3の画像 3
    • Using a punch down tool, force each individual wire deep into the base of the appropriate slots on the RJ-45 Keystone Jack.
    • When using a metal punch down tool, make sure to have the long edge of the tool on the exterior of the RJ-45 Keystone Jack. This part of metal punch down tools act as a cutting function to automatically remove excess wiring.
  8. Cat5e RJ-45 Keystone Jack Replacement: 手順 8、 2の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 8、 2の画像 2
    • Once each wire is placed into the correct slots, use your punch down tool a second time in order to ensure that each wire is connected securely to the RJ-45 Keystone Jack.
  9. Cat5e RJ-45 Keystone Jack Replacement: 手順 9、 3の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 9、 3の画像 2 Cat5e RJ-45 Keystone Jack Replacement: 手順 9、 3の画像 3
    • Using utility scissors, cut off any external wiring on the outside of the RJ-45 Keystone Jack.
    • Cut as close to the RJ-45 Keystone Jack as possible.
  10. Cat5e RJ-45 Keystone Jack Replacement: 手順 10、 3の画像 1 Cat5e RJ-45 Keystone Jack Replacement: 手順 10、 3の画像 2 Cat5e RJ-45 Keystone Jack Replacement: 手順 10、 3の画像 3
    • Align the plastic covering over the exposed wiring within the RJ-45 Keystone Jack.
    • Push the plastic covering against the RJ-45 Keystone Jack until it clicks into place.
終わりに
Your device is now ready for use.
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Austin Olin
メンバー登録日: 10/08/20
539 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team S1-G13, Johnson Fall 2020 Linn Benton Community College, Team S1-G13, Johnson Fall 2020人のメンバー
LBCC-JOHNSON-F20S1G13
1 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 37
過去 30 日: 152
今までの合計 5,668
