メインコンテンツにスキップ
Casio MH-10M Battery Replacement
必要な工具と部品
  1. Casio MH-10M Battery Replacement, BATTERY: 手順 1、 1の画像 1
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Casio MH-10M Battery Replacement: 手順 2、 2の画像 1 Casio MH-10M Battery Replacement: 手順 2、 2の画像 2
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Casio MH-10M Battery Replacement: 手順 3、 2の画像 1 Casio MH-10M Battery Replacement: 手順 3、 2の画像 2
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  4. Casio MH-10M Battery Replacement: 手順 4、 1の画像 1
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  5. Casio MH-10M Battery Replacement: 手順 5、 2の画像 1 Casio MH-10M Battery Replacement: 手順 5、 2の画像 2
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
終わりに
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
26 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sam
メンバー登録日: 09/23/12
959 ポイント
1ガイドが承認済み
3 件のコメント
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 49,212
