メインコンテンツにスキップ
Casio MarineGear wristwatch battery Replacement
必要な工具と部品
  1. Casio MarineGear wristwatch battery Replacement, Opening the back: 手順 1、 2の画像 1 Casio MarineGear wristwatch battery Replacement, Opening the back: 手順 1、 2の画像 2
    • Use a Phillips #00 to remove the 4 screws holding the back.
  2. Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: 手順 2、 3の画像 1 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: 手順 2、 3の画像 2 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: 手順 2、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use the tweezers to remove the plastic ring that aligns the movement.
    • In this case the watch didn't have a battery installed, but to get the battery out you have to use the tweezers and unhook the latch holding the battery in place.
    • The correct battery for this watch is CR2025 3V button cell.
  3. Casio MarineGear wristwatch battery Replacement, Install new battery: 手順 3、 2の画像 1 Casio MarineGear wristwatch battery Replacement, Install new battery: 手順 3、 2の画像 2
    • Insert the new battery into it's place.
    • Latch the battery hook back into it's place, securing the battery.
    • Turn the movement over to verify the watch is now working.
    • You may have to touch the AC (negative) side of battery, to the metal grounding plate. (It's stated on the white label and marks are very clear).
  4. Casio MarineGear wristwatch battery Replacement, Reassemble the watch: 手順 4、 3の画像 1 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: 手順 4、 3の画像 2 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: 手順 4、 3の画像 3
    • Make sure the rubber gasket is placed correctly in it's groove, as it is there for water resistance.
    • Place the back cover on and fasten the 4 Phillips #00 screws securing the back plate.
    • Set the time and date, and your watch is now in working order again.
終わりに
Reassembly is detailed in the guide
作成者
2人の作成者と共同で作成されました。
Geir Ove Andersen
メンバー登録日: 06/06/22
7,815 ポイント
5のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,525のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 32
今までの合計 1,148
