メインコンテンツにスキップ
はじめに
If your Casio watch (MTD-120) has been losing time, showing incorrect time or stopping, it most likely has a dead or dysfunctional battery, which requires replacement.
A functional battery provides power to the watch such that the hands of the watch start functioning properly to show correct time.
  1. Place the watch upside down.
    • Place the watch upside down.
  2. Remove the back cover of the watch with  tweezers. This should reveal a plastic cover once the back is removed.
    • Remove the back cover of the watch with tweezers.
    • This should reveal a plastic cover once the back is removed.
  3. Remove the plastic cover with the tweezers. You should now see the battery compartment.
    • Remove the plastic cover with the tweezers.
    • You should now see the battery compartment.
  4. Remove the battery with the tweezers.
    • Remove the battery with the tweezers.
    • Use your fingers to remove the battery if you find it difficult using the tweezers.
  5. Insert the new battery by pushing down gently.
    • Insert the new battery by pushing down gently.
    • The battery needed for this watch is an SR920SW.
    • Recycle the old battery.
    • Where To Recycle Batteries
  6. Place the plastic cover back over battery compartment. Align the marked area of the plastic cover with the crown of the watch.
    • Place the plastic cover back over battery compartment.
    • Align the marked area of the plastic cover with the crown of the watch.
    • The crown is the knob that is used to set the watch.
  7. Put the cover back and tighten it shut by pressing on it.
    • Put the cover back and tighten it shut by pressing on it.
終わりに
Follow the link provided in step 5 to find more information on recycling your old batteries.
Isabel Chavez
メンバー登録日: 2020年01月16日
145 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G1, Raign Spring 2020 University of North Texas, Team S1-G1, Raign Spring 2020人のメンバー
UNT-RAIGN-S20S1G1
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 41
今までの合計 732
