メインコンテンツにスキップ
Casio G’zOne Commando 4G LTE Motherboard Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Open back cover.: 手順 1、 1の画像 1
    • This device is waterproof and well sealed, so it is difficult to open this handset.
    • Start by opening the cover of the handset.
    • Do not use your nails to open the cover. Use the iFixit Opening Tool (refer to the image).
  2. Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: 手順 2、 2の画像 1 Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: 手順 2、 2の画像 2
    • Move the orange tab to the right side to take out the battery.
    • Remove the battery.
  3. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: 手順 3、 2の画像 1 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: 手順 3、 2の画像 2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  4. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 手順 4、 3の画像 1 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 手順 4、 3の画像 2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 手順 4、 3の画像 3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  5. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove Side-Front cover: 手順 5、 1の画像 1
    • Pull the side front cover off the face of the phone.
  6. Casio G’zOne Commando 4G LTE Motherboard Replacement: 手順 6、 3の画像 1 Casio G’zOne Commando 4G LTE Motherboard Replacement: 手順 6、 3の画像 2 Casio G’zOne Commando 4G LTE Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  7. Casio G’zOne Commando 4G LTE Motherboard Replacement: 手順 7、 1の画像 1
    • Gently pull off the motherboard cover.
  8. Casio G’zOne Commando 4G LTE Motherboard Replacement: 手順 8、 1の画像 1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  9. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: 手順 9、 2の画像 1 Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: 手順 9、 2の画像 2
    • Gently remove the motherboard with the spudger.
終わりに
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Brett Boehm
メンバー登録日: 09/25/14
281 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-5, Brown Fall 2014 USF Tampa, Team 1-5, Brown Fall 2014人のメンバー
USFT-BROWN-F14S1G5
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 839
