はじめに
After removing the battery and motherboard from your device you will be able to simply remove the camera from the mother board after following the steps provided.
必要な工具と部品
First, you are going to want to take out the two front screws from the device.
The screws are 4mm in length and require a Y0 bit to remove
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
