メインコンテンツにスキップ
Casio FX-115ES PLUS Battery Replacement
必要な工具と部品
  1. Casio FX-115ES PLUS Battery Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the calculator by pressing the [shift] button.
    • Press the [AC] [OFF] button to turn off the calculator by pressing the [shift] button.
  2. Casio FX-115ES PLUS Battery Replacement: 手順 2、 3の画像 1 Casio FX-115ES PLUS Battery Replacement: 手順 2、 3の画像 2 Casio FX-115ES PLUS Battery Replacement: 手順 2、 3の画像 3
    • Turn the calculator the other way around so that the small panel in the top right corner of the back of the calculator faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • Don't force the screwdriver on the screw, as it can strip the screw
  3. Casio FX-115ES PLUS Battery Replacement: 手順 3、 1の画像 1
    • Remove the battery cover.
  4. Casio FX-115ES PLUS Battery Replacement: 手順 4、 1の画像 1
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to take the battery out carefully.
    • Be careful when removing the battery to avoid any damage.
  5. Casio FX-115ES PLUS Battery Replacement: 手順 5、 1の画像 1
    • Place the new 357 oxide button battery into the calculator.
    • Make sure that the + sign is at the bottom.
  6. Casio FX-115ES PLUS Battery Replacement: 手順 6、 3の画像 1 Casio FX-115ES PLUS Battery Replacement: 手順 6、 3の画像 2 Casio FX-115ES PLUS Battery Replacement: 手順 6、 3の画像 3
    • Reattach the battery cover.
    • Insert the screw back in place along with the cover using a Phillips #0 screwdriver.
    • Make sure to turn the screwdriver clockwise to lock the screw in tight, preventing the battery from falling out.
  7. Casio FX-115ES PLUS Battery Replacement: 手順 7、 1の画像 1
    • Reset the calculator by pressing [ON].
    • Press the [Shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] [ALL] button option.
    • Press the [=] [yes] button to accept.
    • Press the [AC] key to reset completely.
終わりに
You have successfully replaced a Casio FX-115ES PLUS battery
作成者
1人の作成者と共同作成されました。
Rodrigo Lopez
メンバー登録日: 01/23/23
145 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 2-1, Briggs Spring 2023 CSU Los Angeles, Team 2-1, Briggs Spring 2023人のメンバー
CSULA-BRIGGS-S23S2G1
2 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 83
今までの合計 3,681
