はじめに
If your Casio Exilim EX-Z850 is no longer working correctly, you most likely need to replace the motherboard.
The motherboard is responsible for keeping your device functioning properly. It connects all of the principle components of the camera. If the motherboard is not working correctly, everything has the possibility of not working right. If your device continues to malfunction, you should replace the motherboard.
Make sure to power down your camera before you begin.
必要な工具と部品
Using the Phillips #00 screwdriver, remove the four screws from the side of the speaker.
Remove the frame on the back side of the camera where the LCD screen was.
Use the Phillips #00 screwdriver to remove the two screws connecting the frame to the camera.
Slowly pry off the frame from the camera.
After removing the frame, a plastic piece with two yellow buttons should fall off.
ある他の人がこのガイドを完成しました。
