メインコンテンツにスキップ
Casio Exilim EX-Z850 LCD Screen Replacement
必要な工具と部品
  1. Casio Exilim EX-Z850 LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Remove the two screws on the side of the speakers with the Phillips 00 Screwdriver, on the portion of the camera that is a part of the back casing.
    • Label screws (where they came from and what step) and set aside in the sorting tray.
  2. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 2、 2の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 2、 2の画像 2
    • Remove the two back screws on the bottom of the camera on the same side as the LCD screen.
    • Note: The bottom screws are longer than the top ones, so label the screws accordingly for ease in reassembly. (See attached picture.)
  3. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 3、 1の画像 1
    • Remove the screws on the opposite of the speakers.
    • Label the screws accordingly and add to the sorting tray.
  4. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 4、 2の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Once all screws have been removed, gently pry open the bottom casing.
    • Use the tweezers to carefully remove the ribbon from the LCD screen- NOT from the back casing itself.
    • Set the bottom casing aside.
    • Navigation button may fall out so be cautious of this and set aside if needed.
  5. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 5、 3の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 5、 3の画像 2 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 5、 3の画像 3
    • Use the tweezers to pry the LCD screen off from the openings. There are 5 spots that the tweezers can go in to pry the LCD screen off (see attached pictures).
    • There is a ribbon attached to the screen. Be sure not to pull this ribbon off the screen.
  6. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 6、 2の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 6、 2の画像 2
    • Use the tweezers to lift up the LCD screen.
    • Grab the LCD screen with the index finger and thumb, leave the ribbon attached to the screen and leave it on the side.
    • Be sure to be very gentle with the LCD screen.
  7. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 7、 3の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 7、 3の画像 2 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 7、 3の画像 3
    • Under the LCD screen you will see an LCD casing. You will want to GENTLY pry this off using the tweezers.
    • The casing may possibly be attached to the LCD screen. If so, leave it attached to the screen.
  8. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 8、 3の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 8、 3の画像 2 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 8、 3の画像 3
    • Use the tweezers to flip open the connectors holding the ribbon.
    • Pull out the LCD screen with the ribbon from the camera.
    • THIS STEP IS WHEN WHERE YOU SHOULD USE CAUTION AND BE VERY GENTLE!
  9. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 9、 2の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 9、 2の画像 2
    • Your LCD screen is now detached.
    • Locate the replacement screen that you will now attach.
  10. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 10、 1の画像 1
    • Reconnect the LCD ribbon to the connectors and flip back down.
    • Ribbon should be inserted straight in and to the right side.
  11. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 11、 1の画像 1
    • Reattach the LCD casing.
    • Flip it back into place.
  12. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 12、 2の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 12、 2の画像 2
    • Make sure the LCD screen is firmly connected to the camera.
    • Slightly push the LCD screen down with one finger until you hear a click.
  13. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 13、 2の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 13、 2の画像 2
    • Reattach the back casing as well as the small ribbon with it to the camera body.
    • Be carefully reattaching the case. Using both hands might help.
  14. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 14、 1の画像 1
    • Locate the labeled screws from Step 2-on the bottom of the camera.
    • These are the longer screws. Screw them back in.
    • The picture shown does not show the right screw removed and ready to be replaced due to an issue with this specific camera.
  15. Casio Exilim EX-Z850 LCD Screen Replacement: 手順 15、 3の画像 1 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 15、 3の画像 2 Casio Exilim EX-Z850 LCD Screen Replacement: 手順 15、 3の画像 3
    • Locate the labeled screws from Step 1 and Step 3-on the side of the camera.
    • These are the shorter screws. Screw them back in.
    • Congratulations! Your camera has been reassembled.
終わりに
By now you should have been able to get your Casio Exilim EX-Z850 camera's LCD screen functioning.
ある他の人がこのガイドを完成しました。
作成者
10人の作成者と共同で作成されました。
Christian
メンバー登録日: 01/28/11
320 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S4G38
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 28
今までの合計 3,222
