メインコンテンツにスキップ
Casio Exilim EX-Z70 Memory Card Replacement
  1. Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: 手順 1、 3の画像 1 Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: 手順 1、 3の画像 2 Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: 手順 1、 3の画像 3
    • Orient the camera with the lens facing to the right and the bottom of the camera toward you.
    • Grasping the camera tightly, press downward firmly on the piece with the label and slide it towards the LCD screen (to the left).
    • The flap will then swing upward.
  2. Casio Exilim EX-Z70 Memory Card Replacement: 手順 2、 2の画像 1 Casio Exilim EX-Z70 Memory Card Replacement: 手順 2、 2の画像 2
    • Push down on the memory card (located behind the battery) and then release pressure completely.
    • The memory card will automatically rise part way out of its compartment.
    • Grasp the memory card on each side and simply slide it out of its compartment to remove it.
  3. Casio Exilim EX-Z70 Memory Card Replacement: 手順 3、 3の画像 1 Casio Exilim EX-Z70 Memory Card Replacement: 手順 3、 3の画像 2 Casio Exilim EX-Z70 Memory Card Replacement: 手順 3、 3の画像 3
    • If your memory card is locked, there is a metal slider on the left side that can be moved up to unlock the memory card.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Paul Fallon
メンバー登録日: 04/10/12
141 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 17-28, Amido Spring 2012 Cal Poly, Team 17-28, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S17G28
4 メンバー
14のガイドは作成済み
2 件のコメント
My Casio camera works great until I insert the memory card. When it doesn't have the memory card, it turns on, the lenses come out and everything but as soon as I insert the memory card, the lenses will come out have way, and then the camera shuts off like that. The only way to get the lenses to get inside and the camera to turn on, is to remove the memory card. HELP ME PLEASE!
Miriam - 返信
I have a similar issue. My camera won’t recognize the SD card! It’ll turn on & take pic’s in the Memory area, but them it’s FULL after a few. Isn’t there something that can be done?
I see NO ONE HAS ANSWERED THE LAST PERSONS QUESTION….????????????
Lynn Lehr - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 43
今までの合計 3,360
