はじめに
When the camera will not turn on it is possible that the battery has lost charge. This guide will show how to locate and remove the battery so that it can be charged.
  1. Orient the camera with the lens facing to the right and the bottom of the camera facing up towards you. Grasping the camera tightly, press downward firmly on the piece with the label and slide it to the left (towards the LCD screen). The flap will then swing upward.
    • Orient the camera with the lens facing to the right and the bottom of the camera facing up towards you.
    • Grasping the camera tightly, press downward firmly on the piece with the label and slide it to the left (towards the LCD screen).
    • The flap will then swing upward.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. With the battery now exposed, pull the dark gray tab away from the battery. The battery is no longer secured in the camera.
    • With the battery now exposed, pull the dark gray tab away from the battery.
    • The battery is no longer secured in the camera.
  4. Firmly grasp each side of the battery and pull it out of its compartment.
    • Firmly grasp each side of the battery and pull it out of its compartment.
まとめ
ある他の人がこのガイドを完成しました。
Jenn Eberts
メンバー登録日: 2012年04月10日
221 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-28, Amido Spring 2012 Cal Poly, Team 17-28, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S17G28
4 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 22
今までの合計 2,379
