必要な工具と部品
Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
Locate the small grey ribbon cable towards the bottom of the device. It should be located above the battery slot. Pinch both sides of the ribbon cable and pull it out.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
