メインコンテンツにスキップ
Casio Cassiopeia E-125 Key Pad Replacement
必要な工具と部品
  1. Casio Cassiopeia E-125 Key Pad Replacement, Battery: 手順 1、 1の画像 1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Key Pad Replacement: 手順 2、 1の画像 1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Key Pad Replacement: 手順 3、 1の画像 1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Key Pad Replacement: 手順 4、 1の画像 1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Key Pad Replacement, Touch Screen: 手順 5、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Key Pad Replacement: 手順 6、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Key Pad Replacement: 手順 7、 1の画像 1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Key Pad Replacement: 手順 8、 1の画像 1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Key Pad Replacement: 手順 9、 1の画像 1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Key Pad Replacement: 手順 10、 1の画像 1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Key Pad Replacement: 手順 11、 2の画像 1 Casio Cassiopeia E-125 Key Pad Replacement: 手順 11、 2の画像 2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
  12. Casio Cassiopeia E-125 Key Pad Replacement, Key Pad: 手順 12、 1の画像 1
    • Use the Phillips #00 screwdriver and remove the five screws from the daughterboard.
  13. Casio Cassiopeia E-125 Key Pad Replacement: 手順 13、 1の画像 1
    • Pull the ribbon cable out of its port on the back of the keypad.
  14. Casio Cassiopeia E-125 Key Pad Replacement: 手順 14、 1の画像 1
    • Now, lift the keypad off the front case.
終わりに
作成者
6人の作成者と共同で作成されました。
Ryan Fernandez
メンバー登録日: 04/03/12
47 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-4, Forte Spring 2012 Cal Poly, Team 5-4, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S5G4
6 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 616
