メインコンテンツにスキップ
Casio CZ-1000 Power Switch Replacement
必要な工具と部品
  1. Casio CZ-1000 Power Switch Replacement, Backplate: 手順 1、 2の画像 1 Casio CZ-1000 Power Switch Replacement, Backplate: 手順 1、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Power Switch Replacement: 手順 2、 3の画像 1 Casio CZ-1000 Power Switch Replacement: 手順 2、 3の画像 2 Casio CZ-1000 Power Switch Replacement: 手順 2、 3の画像 3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Power Switch Replacement: 手順 3、 3の画像 1 Casio CZ-1000 Power Switch Replacement: 手順 3、 3の画像 2 Casio CZ-1000 Power Switch Replacement: 手順 3、 3の画像 3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Power Switch Replacement, Power Switch: 手順 4、 1の画像 1
    • Remove the two 5.5 mm screws holding the power switch to the case using a Phillips #1 screwdriver.
  5. Casio CZ-1000 Power Switch Replacement: 手順 5、 3の画像 1 Casio CZ-1000 Power Switch Replacement: 手順 5、 3の画像 2 Casio CZ-1000 Power Switch Replacement: 手順 5、 3の画像 3
    • Heat the soldering iron and use a desoldering braid or pump to remove the solder from the pins of the old switch.
    • Once the solder is removed, gently pull the old switch out of its place.
    • If the replacement switch doesn’t have pre-attached leads, you’ll need to solder wires to it. If it has leads, align them with the matching holes on the PCB where the old switch was connected.
    • Position the new switch in place, ensuring the leads align correctly with the pads on the PCB. Solder the leads securely, using just enough solder to create a strong connection without any excess that might cause shorts.
終わりに
作成者
3人の作成者と共同で作成されました。
Luke Farmer
メンバー登録日: 11/05/24
235 ポイント
1ガイドが承認済み
チーム
Cuesta, Team 60-3, Krynen Fall 2024 Cuesta, Team 60-3, Krynen Fall 2024人のメンバー
CUESTA-KRYNEN-F24S60G3
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 33
