メインコンテンツにスキップ
Casing and Trigger
必要な工具と部品
  1. Casing and Trigger, Fellowes T7CM Casing and Trigger Replacement: 手順 1、 1の画像 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Casing and Trigger: 手順 2、 1の画像 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    The FIFTH screw is under the paper lable
    dontabb - 返信
  3. Casing and Trigger: 手順 3、 1の画像 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Casing and Trigger: 手順 4、 1の画像 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
John Wisthoff
メンバー登録日: 10/12/16
487 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S2G2
4 メンバー
16のガイドは作成済み
2 件のコメント
-Group 1 Recommendations-
Use Caution - Should use the 'Caution' bullet. (Click on the bullet to change bullets)
Take note - Should use the 'Note' bullet.
Second to last bullet on the last step - Should be a note because it is not stating a step, it is a note or reminder for the user.
Deanna Jack - 返信
Where can i buy replacement gears for this shredder?
indymoon - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 53
今までの合計 3,638
