メインコンテンツにスキップ
Casdon Dyson Ball On/Off Switch Replacement
必要な工具と部品
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: 手順 1、 1の画像 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: 手順 2、 1の画像 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: 手順 3、 1の画像 1
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: 手順 4、 1の画像 1
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: 手順 5、 1の画像 1
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
  6. Casdon Dyson Ball On/Off Switch Replacement: 手順 6、 1の画像 1
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: 手順 7、 1の画像 1
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
終わりに
作成者
1人の作成者と共同作成されました。
Seldon Price
メンバー登録日: 11/07/17
612 ポイント
5のガイドは作成済み
チーム
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017人のメンバー
IUPUI-HARLEY-F17S3G5
3 メンバー
10のガイドは作成済み
コメント 1 件
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 30
今までの合計 2,083
