メインコンテンツにスキップ
Carrier 14 Seer Heat Pump Capacitor Replacement
必要な工具と部品
  1. Carrier 14 Seer Heat Pump Capacitor Replacement, Capacitor: 手順 1、 3の画像 1 Carrier 14 Seer Heat Pump Capacitor Replacement, Capacitor: 手順 1、 3の画像 2 Carrier 14 Seer Heat Pump Capacitor Replacement, Capacitor: 手順 1、 3の画像 3
    • Caution: Use a non-contact voltage tester or a multimeter to make sure that the breaker is not electrically charged. If you do not have access to a multimeter, tap the breaker box with the back of your hand. If you use the palm of your hand and there is a charge, your hand will clench, making it hard to remove your hand from the box.
    • Turn off your heat pump unit's breaker.
  2. Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 2、 3の画像 1 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 2、 3の画像 2 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 2、 3の画像 3
    • Remove the emergency shutoff switch by firmly grasping it and pulling it out.
  3. Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 3、 2の画像 1 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 3、 2の画像 2
    • Use a 5/16 nut driver to remove the single bolt and remove the cover by sliding it downwards.
  4. Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 4、 3の画像 1 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 4、 3の画像 2 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 4、 3の画像 3
    • Using an insulated screwdriver, tap two of the capacitor's ports at a time to remove any excess charge.
  5. Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 5、 1の画像 1
    • Unplug and remove the capacitor from the unit.
  6. Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 6、 3の画像 1 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 6、 3の画像 2 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 6、 3の画像 3
    • Replace and plug in the new capacitor.
    • The brown wire will go to the Fan port.
    • The yellow wires will go to the C port.
    • The blue wire will go to the Herm port.
    • As long as the wires are on the correct port, it does not matter which connector you use.
  7. Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 7、 3の画像 1 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 7、 3の画像 2 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 7、 3の画像 3
    • Replace the cover on your unit by sliding it upwards and replacing the single bolt.
  8. Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 8、 3の画像 1 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 8、 3の画像 2 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 8、 3の画像 3
    • Plug in the Emergency Shutoff switch.
    • Make sure that the connectors are on the lower side.
  9. Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 9、 2の画像 1 Carrier 14 Seer Heat Pump Capacitor Replacement: 手順 9、 2の画像 2
    • Turn on the breakers.
終わりに
Replacing the capacitor should fix your air conditioner. Please note that the unit will take some time to charge the capacitor before starting up again.
作成者
2人の作成者と共同で作成されました。
Caleb Gross
メンバー登録日: 09/19/23
175 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 22-4, Watkins Fall 2023 Austin Community College, Team 22-4, Watkins Fall 2023人のメンバー
AUSTINCC-WATKINS-F23S22G4
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 44
今までの合計 838
