メインコンテンツにスキップ
Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement
必要な工具と部品
  1. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Caribou Coffee CC-EKV8SS7  Base Disassembly: 手順 1、 2の画像 1 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Caribou Coffee CC-EKV8SS7  Base Disassembly: 手順 1、 2の画像 2
    • Unplug the unit before disassembling to avoid electrocution.
    • Remove the five (10mm) Y screws from the bottom of the base. Three are in a triangle around the center and two are on the corners of the flat edge.
  2. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: 手順 2、 3の画像 1 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: 手順 2、 3の画像 2 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: 手順 2、 3の画像 3
    • Now you will need to 'unlock' the top and bottom of the base from each other. On the flat edge, there is a rectangle inset with one side cut out. Insert a metal spudger about 1/2'' in to the opening to toggle open an interior tab.
    • With the metal tool still inserted, use an opening tool between the black and silver sides to pry the base open.
  3. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: 手順 3、 2の画像 1 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: 手順 3、 2の画像 2
    • Once you have the halves opened at least 1/4'', remove the metal key and rotate the base a quarter turn in any direction.
    • Continue using the spudger to pry open the base at each quarter turn until the sides separate easily.
    • The black bottom will catch on the power cord plug, to prevent total dismantlement.
  4. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: 手順 4、 3の画像 1 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: 手順 4、 3の画像 2 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: 手順 4、 3の画像 3
    • To uninstall the element, start by removing the 4 copper connectors and 1 metal tab from the power cord. This will require you to wiggle and pull the connectors out.
    • Once those pieces are detached, you can insert them into the replacement part, as they were.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Melanie Preston
メンバー登録日: 07/01/17
113 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G3, Liner Summer 2017 UW Tacoma, Team S1-G3, Liner Summer 2017人のメンバー
UWT-LINER-SU17S1G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 437
