はじめに
The left panel is structurally significant to the ventilator but is not fixed to any other components. Therefore it is necessary to remove the left panel for a vast majority of service to be done on internal components of the ventilator. You will need a Phillips screwdriver to complete this guide. This part is strictly structural, however it needs to be removed to access many of the parts inside.
必要な工具と部品
手順1 Cardinal Health Vela Ventilator Power Cable Removal
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
手順6 Cardinal Health Vela Ventilator Battery Tray Removal
注意: 手順 6-8 は、作業進行中としてマークされている ガイド から引用されています。
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
