Allow time for the engine to warm up completely
Attach carburetor synchronization tool to one of the carburetors
Observe the relative reading, and remember it.
This reading is a measurement of the airflow speed
Set the synchronization device on the other carburetor.
Using a Flathead screw-driver, twist the idle speed screw in to raise the flow, and out to lower it.
Recheck both carburetors and adjust as needed to get the flow as equal as possible.
Now, the idle mixture screws must be adjusted.
It is important that when the screws are adjusted they are adjusted the same amount in the same direction.
Turn both screws in, or out an 1/8 or a turn at a time until the fastest idle speed is achieved.
Before proceeding with this step you should have already checked your ignition timing, if you have not do it now, and then continue from here.
Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
Once more, it is important to adjust the screws the same amount.
Rotate the aircleaner back to its original position, and re-tighten the 3/8 nuts on the retainers
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
