この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If you need to replace the outside casing, follow this guide. The outside casing is essential to keeping everything inside in place, and protecting the internal structures of the device. If there is cosmetic damage or significant disfigurement, replacement of the metal outside casing is suggested. For this guide, you will need the Torx Security T10 Bit Screwdriver as well as the extension bit.
必要な工具と部品
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
