メインコンテンツにスキップ
Canon ZR70MC Front Panel Replacement
必要な工具と部品
  1. Canon ZR70MC Front Panel Replacement, Front Panel: 手順 1、 2の画像 1 Canon ZR70MC Front Panel Replacement, Front Panel: 手順 1、 2の画像 2
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC Front Panel Replacement: 手順 2、 1の画像 1
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC Front Panel Replacement: 手順 3、 3の画像 1 Canon ZR70MC Front Panel Replacement: 手順 3、 3の画像 2 Canon ZR70MC Front Panel Replacement: 手順 3、 3の画像 3
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC Front Panel Replacement: 手順 4、 3の画像 1 Canon ZR70MC Front Panel Replacement: 手順 4、 3の画像 2 Canon ZR70MC Front Panel Replacement: 手順 4、 3の画像 3
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC Front Panel Replacement: 手順 5、 2の画像 1 Canon ZR70MC Front Panel Replacement: 手順 5、 2の画像 2
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC Front Panel Replacement: 手順 6、 3の画像 1 Canon ZR70MC Front Panel Replacement: 手順 6、 3の画像 2 Canon ZR70MC Front Panel Replacement: 手順 6、 3の画像 3
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC Front Panel Replacement: 手順 7、 3の画像 1 Canon ZR70MC Front Panel Replacement: 手順 7、 3の画像 2 Canon ZR70MC Front Panel Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
khalid clarke
メンバー登録日: 09/26/17
824 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team S13-G2, Boczar Fall 2017 USF Tampa, Team S13-G2, Boczar Fall 2017人のメンバー
USFT-BOCZAR-F17S13G2
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 199
