メインコンテンツにスキップ
Canon Vixia HF S10 Camcorder Power Button Replacement
必要な工具と部品
  1. Canon Vixia HF S10 Camcorder Power Button Replacement, Power Button: 手順 1、 1の画像 1
    • Turn the camcorder upside down.
    • Remove the three 3x4 mm Phillips screws securing from the black plastic case.
  2. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 2、 3の画像 1 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 2、 3の画像 2 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 2、 3の画像 3
    • Open the LCD screen.
    • Remove the three 3x4 mm Phillips screws that hold the black panel plastic case together.
    • Remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw from the inner corner between the panel and the LCD screen.
  3. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 3、 2の画像 1 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 3、 2の画像 2
    • Remove the black plastic covering with your fingers.
    • Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  4. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 4、 2の画像 1 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 4、 2の画像 2
    • Using your fingers, remove the panel from the base of the camcorder.
    • Remove the two 1x2.5 mm Phillips screws.
  5. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 5、 1の画像 1
    • Remove the four 2x2.25 mm Phillips screws.
  6. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 6、 2の画像 1 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 6、 2の画像 2
    • Turn the camcorder to the side and remove the strap.
  7. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 7、 2の画像 1 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 7、 2の画像 2
    • Using a plastic opening tool, pry off the side panel from the base of the camcorder.
    • Remove the two 2x2.5mm Phillips screws located at the top
  8. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 8、 1の画像 1
    • Remove the two 3x4 mm Phillips screws beneath the two covers (AV & DCIN).
  9. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 9、 3の画像 1 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 9、 3の画像 2 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 9、 3の画像 3
    • Slide open the "Optical Image Stabilizer" cover located at the top of the camcorder.
    • Remove the four 3x2.5 mm Phillips screws.
    • Using your fingers, remove the metal casing.
  10. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 10、 3の画像 1 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 10、 3の画像 2 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 10、 3の画像 3
    • Using your fingers pop off the top cover of the camcorder.
    • Remove the three 3x4 mm Phillips screws and one 2x2.5 mm Phillips screw located beneath the top cover.
    • Remove the two 3x2.5 mm Phillips screws from the metal casing located underneath the top cover.
  11. Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 11、 2の画像 1 Canon Vixia HF S10 Camcorder Power Button Replacement: 手順 11、 2の画像 2
    • Using your fingers, slightly move the metal casing.
    • Remove the power button.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Olivia
メンバー登録日: 03/03/15
343 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team 13-1, Blackburne Winter 2015 Sam Houston State, Team 13-1, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S13G1
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 9
今までの合計 1,936
