メインコンテンツにスキップ
Canon Vixia HF R600 LCD screen Replacement
必要な工具と部品
  1. Canon Vixia HF R600 LCD screen Replacement, Handstrap: 手順 1、 2の画像 1 Canon Vixia HF R600 LCD screen Replacement, Handstrap: 手順 1、 2の画像 2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 LCD screen Replacement: 手順 2、 2の画像 1 Canon Vixia HF R600 LCD screen Replacement: 手順 2、 2の画像 2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 LCD screen Replacement, Battery: 手順 3、 2の画像 1 Canon Vixia HF R600 LCD screen Replacement, Battery: 手順 3、 2の画像 2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 LCD screen Replacement, Casing: 手順 4、 2の画像 1 Canon Vixia HF R600 LCD screen Replacement, Casing: 手順 4、 2の画像 2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 LCD screen Replacement: 手順 5、 2の画像 1 Canon Vixia HF R600 LCD screen Replacement: 手順 5、 2の画像 2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 LCD screen Replacement: 手順 6、 2の画像 1 Canon Vixia HF R600 LCD screen Replacement: 手順 6、 2の画像 2
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 LCD screen Replacement, LCD Screen: 手順 7、 1の画像 1
    • Remove the LCD display from the camera body.
  8. Canon Vixia HF R600 LCD screen Replacement: 手順 8、 3の画像 1 Canon Vixia HF R600 LCD screen Replacement: 手順 8、 3の画像 2 Canon Vixia HF R600 LCD screen Replacement: 手順 8、 3の画像 3
    • Rotate the display hinge to reveal two 4mm Phillips #00 screws.
    • Before removing, use the plastic opening tool to pry apart the plastic hinge cover.
    • Remove the cover.
  9. Canon Vixia HF R600 LCD screen Replacement: 手順 9、 3の画像 1 Canon Vixia HF R600 LCD screen Replacement: 手順 9、 3の画像 2 Canon Vixia HF R600 LCD screen Replacement: 手順 9、 3の画像 3
    • Remove the two 4mm Phillips #00 screws.
    • Pull the LCD display back cover to reveal the motherboard covering the screen.
    • Remove one more 4mm Phillips #00 screw.
  10. Canon Vixia HF R600 LCD screen Replacement: 手順 10、 3の画像 1 Canon Vixia HF R600 LCD screen Replacement: 手順 10、 3の画像 2 Canon Vixia HF R600 LCD screen Replacement: 手順 10、 3の画像 3
    • Pull the screen protector away from the LCD display.
    • Use a plastic opening tool to lift the ribbon connector tab.
    • The LCD display can now be replaced!
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Brian Luna
メンバー登録日: 02/10/16
483 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 14-4, Lacy Spring 2016 USF Tampa, Team 14-4, Lacy Spring 2016人のメンバー
USFT-LACY-S16S14G4
3 メンバー
16のガイドは作成済み
6 件のコメント
Where did you find the replacement LCD screen at? Specifically I am looking for the Vixia HF M41A version
Jeff Onsrud - 返信
I can’t find the replacement lcd for my model canon vixia hf R600, can you point me in the right direction?
Seth Flake - 返信
Gotta hf r800 and need screen, any ideas where?
Sean - 返信
Very nice step by step guidance. Where can I find the Replacement lcd screen for Canon Vixia HFR 600 camera. Will appreciate that!
Thanks!
shelaindrab - 返信
I have a Canon Vixia HF R52, and with all my research it looks like all of these are the same LCD: HF-R52, HF-R82, HF-R600.....and maybe even the HF-R48, and HF-R406, and HF-R706.
pe.labs - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 20
今までの合計 2,256
