メインコンテンツにスキップ
Canon Vixia HF R600 Camera Lens Replacement
必要な工具と部品
  1. Canon Vixia HF R600 Camera Lens Replacement, Handstrap: 手順 1、 2の画像 1 Canon Vixia HF R600 Camera Lens Replacement, Handstrap: 手順 1、 2の画像 2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Camera Lens Replacement: 手順 2、 2の画像 1 Canon Vixia HF R600 Camera Lens Replacement: 手順 2、 2の画像 2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Camera Lens Replacement, Battery: 手順 3、 2の画像 1 Canon Vixia HF R600 Camera Lens Replacement, Battery: 手順 3、 2の画像 2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Camera Lens Replacement, Casing: 手順 4、 2の画像 1 Canon Vixia HF R600 Camera Lens Replacement, Casing: 手順 4、 2の画像 2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Camera Lens Replacement: 手順 5、 2の画像 1 Canon Vixia HF R600 Camera Lens Replacement: 手順 5、 2の画像 2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Camera Lens Replacement: 手順 6、 2の画像 1 Canon Vixia HF R600 Camera Lens Replacement: 手順 6、 2の画像 2
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: 手順 7、 3の画像 1 Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: 手順 7、 3の画像 2 Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: 手順 7、 3の画像 3
    • Remove one 5mm Phillips PH#00 screw from the top of the camera.
    • Pull away the plastic shutter casing; this contains the microphone.
    • Using the plastic opening tool or something similar, carefully disconnect the white 4 pin connector to remove the shutter casing.
  8. Canon Vixia HF R600 Camera Lens Replacement: 手順 8、 2の画像 1 Canon Vixia HF R600 Camera Lens Replacement: 手順 8、 2の画像 2
    • Remove the three 5mm Phillips PH#00 screws surrounding the camera lens.
    • Pull the lens off of the camera and replace.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Brian Luna
メンバー登録日: 02/10/16
483 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 14-4, Lacy Spring 2016 USF Tampa, Team 14-4, Lacy Spring 2016人のメンバー
USFT-LACY-S16S14G4
3 メンバー
16のガイドは作成済み
コメント 1 件
I think you need a part, the lens..... Which is what I also need, which is why I'm here..... Now, if I could just figure out where to get a lens your tutorial would be helpful.
dannyknappy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 609
