メインコンテンツにスキップ
Canon Vixia HF R500 Zoom Control Replacement
必要な工具と部品
  1. Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: 手順 1、 3の画像 1 Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: 手順 1、 3の画像 2 Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: 手順 1、 3の画像 3
    • On the right side of the camcorder remove the grip belt.
  2. Canon Vixia HF R500 Zoom Control  Replacement, Battery: 手順 2、 1の画像 1
    • Hold on to the battery.
  3. Canon Vixia HF R500 Zoom Control  Replacement: 手順 3、 1の画像 1
    • On the bottom of the battery hold the battery release switch.
  4. Canon Vixia HF R500 Zoom Control  Replacement: 手順 4、 1の画像 1
    • Remove the battery slowly away from the camcorder.
    • Removing the battery quick or in a different angle may cause sparks and damage to device.
  5. Canon Vixia HF R500 Zoom Control  Replacement, Canon Vixia HF R500 Disassembly: 手順 5、 2の画像 1 Canon Vixia HF R500 Zoom Control  Replacement, Canon Vixia HF R500 Disassembly: 手順 5、 2の画像 2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  6. Canon Vixia HF R500 Zoom Control  Replacement: 手順 6、 1の画像 1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  7. Canon Vixia HF R500 Zoom Control  Replacement: 手順 7、 1の画像 1
    • Remove the side piece plate.
  8. Canon Vixia HF R500 Zoom Control  Replacement: 手順 8、 1の画像 1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  9. Canon Vixia HF R500 Zoom Control  Replacement: 手順 9、 1の画像 1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  10. Canon Vixia HF R500 Zoom Control  Replacement: 手順 10、 1の画像 1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  11. Canon Vixia HF R500 Zoom Control  Replacement: 手順 11、 3の画像 1 Canon Vixia HF R500 Zoom Control  Replacement: 手順 11、 3の画像 2 Canon Vixia HF R500 Zoom Control  Replacement: 手順 11、 3の画像 3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  12. Canon Vixia HF R500 Zoom Control  Replacement: 手順 12、 1の画像 1
    • Remove the top piece.
  13. Canon Vixia HF R500 Zoom Control  Replacement, Speaker: 手順 13、 2の画像 1 Canon Vixia HF R500 Zoom Control  Replacement, Speaker: 手順 13、 2の画像 2
    • Remove the three 6mm Philips #000 screws holding the black record piece.
  14. Canon Vixia HF R500 Zoom Control  Replacement: 手順 14、 1の画像 1
    • Remove the black record piece.
  15. Canon Vixia HF R500 Zoom Control  Replacement: 手順 15、 2の画像 1 Canon Vixia HF R500 Zoom Control  Replacement: 手順 15、 2の画像 2
    • Holding the full top piece remove the six 5mm Philips #000 screws holding the metal frame to the top piece.
  16. Canon Vixia HF R500 Zoom Control  Replacement: 手順 16、 1の画像 1
    • Carefully remove the the whole metal frame out of the device piece.
  17. Canon Vixia HF R500 Zoom Control  Replacement: 手順 17、 1の画像 1
    • Replace the defective speaker with a functioning one.
  18. Canon Vixia HF R500 Zoom Control  Replacement, Zoom Control: 手順 18、 2の画像 1 Canon Vixia HF R500 Zoom Control  Replacement, Zoom Control: 手順 18、 2の画像 2
    • Examine the grey zoom input tab located on copper plate.
    • Examine the black plastic zoom slider, on the top cover of the camera
    • Repair or replace damaged components and clear all debris from mechanisms.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
James Walker
メンバー登録日: 01/29/16
461 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team 1-5, Virtue Spring 2016 Western Carolina University, Team 1-5, Virtue Spring 2016人のメンバー
WCU-VIRTUE-S16S1G5
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 241
