メインコンテンツにスキップ
Canon Vixia HF R500 Microphone Replacement
必要な工具と部品
  1. Canon Vixia HF R500 Microphone Replacement, Grip Belt: 手順 1、 3の画像 1 Canon Vixia HF R500 Microphone Replacement, Grip Belt: 手順 1、 3の画像 2 Canon Vixia HF R500 Microphone Replacement, Grip Belt: 手順 1、 3の画像 3
    • On the right side of the camcorder remove the grip belt.
  2. Canon Vixia HF R500 Microphone Replacement, Battery: 手順 2、 1の画像 1
    • Hold on to the battery.
  3. Canon Vixia HF R500 Microphone Replacement: 手順 3、 1の画像 1
    • On the bottom of the battery hold the battery release switch.
  4. Canon Vixia HF R500 Microphone Replacement: 手順 4、 1の画像 1
    • Remove the battery slowly away from the camcorder.
    • Removing the battery quick or in a different angle may cause sparks and damage to device.
  5. Canon Vixia HF R500 Microphone Replacement, Canon Vixia HF R500 Disassembly: 手順 5、 2の画像 1 Canon Vixia HF R500 Microphone Replacement, Canon Vixia HF R500 Disassembly: 手順 5、 2の画像 2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  6. Canon Vixia HF R500 Microphone Replacement: 手順 6、 1の画像 1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  7. Canon Vixia HF R500 Microphone Replacement: 手順 7、 1の画像 1
    • Remove the side piece plate.
  8. Canon Vixia HF R500 Microphone Replacement: 手順 8、 1の画像 1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  9. Canon Vixia HF R500 Microphone Replacement: 手順 9、 1の画像 1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  10. Canon Vixia HF R500 Microphone Replacement: 手順 10、 1の画像 1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  11. Canon Vixia HF R500 Microphone Replacement: 手順 11、 3の画像 1 Canon Vixia HF R500 Microphone Replacement: 手順 11、 3の画像 2 Canon Vixia HF R500 Microphone Replacement: 手順 11、 3の画像 3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  12. Canon Vixia HF R500 Microphone Replacement: 手順 12、 1の画像 1
    • Remove the top piece.
  13. Canon Vixia HF R500 Microphone Replacement, Lens Cover: 手順 13、 1の画像 1
    • Remove the two 5mm Phillips #000 screws near the LCD screen.
  14. Canon Vixia HF R500 Microphone Replacement: 手順 14、 1の画像 1
    • Remove the single 5mm Phillips #000 screw located on the top of the camera near the lens cover.
  15. Canon Vixia HF R500 Microphone Replacement: 手順 15、 1の画像 1
    • Unplug the cord connecting the camera to the lens cover. Grip the white plug near the port and pull it out.
    • Do not pull the cord by the wires. Grip the white plastic plug.
  16. Canon Vixia HF R500 Microphone Replacement: 手順 16、 1の画像 1
    • The lens cover is detached from the camera and can now be removed.
    • Repair or replace damaged components in the lens cover.
    • Ensure lens cover mechanism is free of debris.
  17. Canon Vixia HF R500 Microphone Replacement, Microphone: 手順 17、 1の画像 1
    • Remove one 5mm Philips #000 screw from the lens cap.
  18. Canon Vixia HF R500 Microphone Replacement: 手順 18、 1の画像 1
    • Remove the lens cover and place in a safe place.
  19. Canon Vixia HF R500 Microphone Replacement: 手順 19、 1の画像 1
    • Remove the one 3mm Philips #000 screw that holds the microphone in place.
  20. Canon Vixia HF R500 Microphone Replacement: 手順 20、 1の画像 1
    • Remove the metal plate that holds the microphone.
  21. Canon Vixia HF R500 Microphone Replacement: 手順 21、 1の画像 1
    • Remove the defective microphone out of the lens cap.
  22. Canon Vixia HF R500 Microphone Replacement: 手順 22、 1の画像 1
    • Insert the new microphone in the same place.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Deion Woods
メンバー登録日: 01/29/16
464 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team 1-5, Virtue Spring 2016 Western Carolina University, Team 1-5, Virtue Spring 2016人のメンバー
WCU-VIRTUE-S16S1G5
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 169
