メインコンテンツにスキップ
Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement
必要な工具と部品
  1. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement, Mode-Selection Wheel: 手順 1、 1の画像 1
    • Push down on the black switch located on the side of the camera. This will cause the back of the camera to pop open.
  2. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 2、 2の画像 1 Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 2、 2の画像 2
    • Remove the five screws circled in red from the plastic on the back of the camera.
  3. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 3、 2の画像 1 Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 3、 2の画像 2
    • Pull on the metallic piece that is sticking out from underneath the plastic. This will allow you to remove both the piece of black plastic and the metallic piece from the camera.
  4. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 4、 1の画像 1
    • You should now see the a strip of black plastic covering the back of the display's logic board. Remove the screw circled in red.
  5. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 5、 2の画像 1 Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 5、 2の画像 2
    • Pull on the orange cable connected to the logic board to lift the logic board out of place.
    • Move the logic board out of the way, as it is covering the screw that holds the wheel in place.
    • Make sure you are careful when moving the logic board. Try to avoid touching the top of the board if possible. Also make sure that if you put it down on top of something that the black plastic is still stuck to the bottom (as shown in the second picture).
  6. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 6、 1の画像 1
    • Remove the screw that is circled in red. This is the screw that holds the mode selection wheel in place.
    • Make sure that you do not lose the metal piece that is located underneath the screw. You will need this to install the new wheel.
  7. Canon Sure Shot Z115 Caption Mode-Selection Wheel Replacement: 手順 7、 1の画像 1
    • With the screw holding it in place removed, the mode selection wheel should come right off. Simply remove it from its socket.
終わりに
Congratulations, you have successfully removed the mode selection wheel from your camera. To reassemble your device, follow these instructions in reverse order.
作成者
1人の作成者と共同作成されました。
Mathew Pilozzi
メンバー登録日: 03/30/15
101 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-3, Shastany Spring 2015 UMass Dartmouth, Team 2-3, Shastany Spring 2015人のメンバー
UMASSD-SHASTANY-S15S2G3
5 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 26
今までの合計 1,138
