メインコンテンツにスキップ
Canon Selphy CP720 Circuit Boards Replacement
必要な工具と部品
  1. Canon Selphy CP720 Circuit Boards Replacement, Screen: 手順 1、 1の画像 1
    • Remove the three 6mm Phillips #1 screws.
  2. Canon Selphy CP720 Circuit Boards Replacement: 手順 2、 2の画像 1 Canon Selphy CP720 Circuit Boards Replacement: 手順 2、 2の画像 2
    • Remove the four 8mm Phillips #1 screws, located in each corner of the device.
  3. Canon Selphy CP720 Circuit Boards Replacement: 手順 3、 1の画像 1
    • Grasp one half of the device's shell in each hand, and pull them apart. They are connected, so don't separate them completely.
  4. Canon Selphy CP720 Circuit Boards Replacement: 手順 4、 2の画像 1 Canon Selphy CP720 Circuit Boards Replacement: 手順 4、 2の画像 2
    • Lift the side panel off to expose the inside of the printer.
  5. Canon Selphy CP720 Circuit Boards Replacement: 手順 5、 1の画像 1
    • Remove the four 8mm Phillips #00 screws that hold the upper circuit board to the shell.
  6. Canon Selphy CP720 Circuit Boards Replacement: 手順 6、 1の画像 1
    • Remove two 8mm Phillips #00 screws from the yellow board.
  7. Canon Selphy CP720 Circuit Boards Replacement: 手順 7、 1の画像 1
    • Remove the two 8mm Phillips #00 screws from the screen.
    • Lift off the circuit board, yellow board, and screen.
  8. Canon Selphy CP720 Circuit Boards Replacement: 手順 8、 3の画像 1 Canon Selphy CP720 Circuit Boards Replacement: 手順 8、 3の画像 2 Canon Selphy CP720 Circuit Boards Replacement: 手順 8、 3の画像 3
    • To separate the screen from the circuit board, grasp the data ribbon cable near the base of the black connector on the circuit board and pull parallel to the surface of the board, toward the screen.
  9. Canon Selphy CP720 Circuit Boards Replacement, Circuit Boards: 手順 9、 1の画像 1
    • Turning to the lower half of the printer, remove the two 6mm Philips screws, and the 8mm Philips screw in the hole in the metal plate. Remove the metal plate.
  10. Canon Selphy CP720 Circuit Boards Replacement: 手順 10、 1の画像 1
    • Remove the flanged Philips screw from the circuit board, located just under the large data ribbon connecting both boards.
  11. Canon Selphy CP720 Circuit Boards Replacement: 手順 11、 1の画像 1
    • Locate the connector on the edge of the board near the first two screws that you removed.
    • To unplug the connector from its socket, grasp it by the white plastic connection, and pull out from the circuit board, away from the center.
  12. Canon Selphy CP720 Circuit Boards Replacement: 手順 12、 1の画像 1
    • Locate a second connector further down the same edge of the board .
    • Grasp the white plastic connector by the sides and pull it out, smoothly and firmly.
  13. Canon Selphy CP720 Circuit Boards Replacement: 手順 13、 1の画像 1
    • Locate the third connector hidden under the broad data ribbon.
    • Grab the ribbon cable by the body and pull it out.
  14. Canon Selphy CP720 Circuit Boards Replacement: 手順 14、 1の画像 1
    • Lift the circuit board up off the lower assembly of the printer, exposing the wide, white data ribbon.
  15. Canon Selphy CP720 Circuit Boards Replacement: 手順 15、 2の画像 1 Canon Selphy CP720 Circuit Boards Replacement: 手順 15、 2の画像 2
    • Pull the ribbon connector out of its socket parallel to the circuit board. All of the circuit boards should now be free of the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Peter Ely
メンバー登録日: 09/26/18
836 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team S1-G1, Carnegie Fall 2018 Eastern Washington University, Team S1-G1, Carnegie Fall 2018人のメンバー
EWU-CARNEGIE-F18S1G1
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 14
今までの合計 886
