メインコンテンツにスキップ
はじめに
This guide shows how to replace the printing mechanism for the Canon Selphy CP1200. This replacement may be necessary if the printing mechanism is faulty or is printing poor quality pictures while other device components are working and troubleshooting has failed. It is also a preliminary step for replacing both the battery leads and cooling fan.
パーツ
パーツは指定されていません。
  1. Canon Selphy CP1200 Print Mechanism Replacement, LCD/Buttons: 手順 1、 1の画像 1
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Print Mechanism Replacement: 手順 2、 1の画像 1
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Print Mechanism Replacement: 手順 3、 1の画像 1
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Print Mechanism Replacement: 手順 4、 1の画像 1
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
  5. Canon Selphy CP1200 Print Mechanism Replacement, Motherboard: 手順 5、 1の画像 1
    • Detach the fan cable from the motherboard.
  6. Canon Selphy CP1200 Print Mechanism Replacement: 手順 6、 1の画像 1
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Print Mechanism Replacement: 手順 7、 1の画像 1
    • Unscrew the three 3mm PH000 screws from the motherboard.
  8. Canon Selphy CP1200 Print Mechanism Replacement: 手順 8、 1の画像 1
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Print Mechanism Replacement: 手順 9、 1の画像 1
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
  10. Canon Selphy CP1200 Print Mechanism Replacement, Print Mechanism: 手順 10、 2の画像 1 Canon Selphy CP1200 Print Mechanism Replacement, Print Mechanism: 手順 10、 2の画像 2
    • Open the side door and depress the ink cassette release.
    • Slide out and remove the ink cassette.
  11. Canon Selphy CP1200 Print Mechanism Replacement: 手順 11、 1の画像 1
    • Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
  12. Canon Selphy CP1200 Print Mechanism Replacement: 手順 12、 1の画像 1
    • Lift out the print mechanism of the printer case.
終わりに
2 の人々がこのガイドを完成させました。
W Sherer
メンバー登録日: 2019年01月16日
605 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 58
今までの合計 1,033
