はじめに
This guide shows how to replace the cooling fan of the Canon Selphy CP12000. This replacement may be necessary if the cooling fan is faulty or the device is overheating excessively.
必要な工具と部品
Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
The top assembly, containing both the LCD and buttons, will now be completely free
I have one but the lcd have Been broken can you give me the number of the lcd please
Mrgames-kw - 返信
Unscrew the three 3mm PH000 screws from the motherboard.
As at this point the whole printmechanism-motherboard assembly is already loose in the case, you can also consider taking out the whole thing completely before removing these screws. It is much easier to remove the cables at the bottom when you have a bit more space. You have to bend the plastic case a bit so the USB ports are free, but other than that you should have not have a problem.
(do step 10 first though, if possible) -
Open the side door and depress the ink cassette release.
Slide out and remove the ink cassette.
Lift out the print mechanism of the printer case.
Where to buy print mathematical mechanism part…please help…sir
When I re-assembled the printer, I found it easier to assemble the motherboard and printing unit outside of the case and then putting that assembly back in the case in one go. This gives a lot more room to reinsert the flat cables. (my unit was a CP1300 though, but I think they are identical)
Other than that, great guide. Thanks for posting! -
ある他の人がこのガイドを完成しました。
