メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
パーツ
パーツは指定されていません。
  1. Turn  the camera so the back of it is facing you.
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Unscrew the two 3 mm screws shown on the left side of the LCD screen panel  using a Phillips screwdriver. Unscrew the two 3 mm screws shown on the left side of the LCD screen panel  using a Phillips screwdriver.
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Unscrew the two 3 mm screws shown on the right side of the LCD screen panel. Unscrew the two 3 mm screws shown on the right side of the LCD screen panel. Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Using the plastic opening tool, remove the rear case of the front LCD cover. Using the plastic opening tool, remove the rear case of the front LCD cover.
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
終わりに
Ellis DeVoe
メンバー登録日: 2015年04月14日
574 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S5G12
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 195
