メインコンテンツにスキップ
Canon Powershot SX30 IS Back Camera Housing Replacement
必要な工具と部品
  1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: 手順 1、 2の画像 1 Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: 手順 1、 2の画像 2
    • Position the camera so that the right side is visible as shown.
    • Unscrew the two 6 mm screws shown using a screwdriver.
  2. Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 2、 3の画像 1 Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 2、 3の画像 2 Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 2、 3の画像 3
    • Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
    • Then, unscrew the lone 6mm screw that was under the plastic flap.
  3. Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 3、 2の画像 1 Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 3、 2の画像 2
    • Turn the camera so that the bottom is visible, as shown.
    • Unscrew the three 4mm screws shown red using a screwdriver.
    • Unscrew the single 6mm screw.
    • Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
  4. Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 4、 1の画像 1
    • Turn the camera so the back side is visible, as shown.
    • Unscrew the two 6mm screws.
  5. Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 5、 1の画像 1
    • Gently remove the back cover using the spudger.
    • Exercise caution, as the wire inside is fragile.
  6. Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 6、 2の画像 1 Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 6、 2の画像 2
    • Detach the wire by lifting the small black bar that holds it to the main body of the camera.
  7. Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 7、 1の画像 1
    • Attach the new cover onto the camera.
  8. Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 8、 1の画像 1
    • Reattach the wire to your new rear casing.
  9. Canon Powershot SX30 IS Back Camera Housing Replacement: 手順 9、 1の画像 1
    • Close the back cover, and re-insert appropriate screws.
終わりに
2 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Ellis DeVoe
メンバー登録日: 04/14/15
580 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S5G12
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 1,333
